how to check codes
atxxtm
Springfield, MA
I have been having some trouble starting the SHO lately, and wanted to know the best way to check codes. Should I just take it to AZ and have them run it for me, or is there a way to do it at home w/o the scanner, maybe with a paper clip somehow?
projectSHO89
SHOless In St L
It is unlikely that AZ will be able to check your codes. Most stores now only have the OBDII scanners.
Paper clip time.
Steve
atxxtm
Springfield, MA
aight now, pulled a 551: intake manifold runner control solenoid, a 542: fuel pump open, bad ground, always on, and a 528: voltage at pin 10 or pin 30 (pnp, cpp) (code def. via link from shotimes)so this means... shrug am i hard starting someitmes because of a fuel pump? and what about the other two?
