G'day...are you talking the hard lines or the rubber..??
If it's the rubber...$15-20 then approx. 30 minutes to swap it out followed by a good brake bleed..
If it's the hard lines..well..that's pretty cheap too, but alot more of your time required...just did mine front to back back in May for under $100...took me a couple of days with alot of cursing..
required...3/16 steel brake line roll of 25 ft or you can get numerous pre-made lengths at Napa..just make sure they have the required fittings...$5-10
A good double flare kit will come in handy..$30..usually includes a pipe cutting tool.
1 bag of 3/16 fittings and a bag of 3/16 unions(steel)..$10..try to do the lines WITH_OUT using the unions if you can..I used a few too many, but she seems to be holding up well.
2 lines in from the front ABS pump to the rear proportioning valve, then 1 each out to rear wheels..drivers side is short and easy to do..passenger side goes up in front of the gas tank held in with a few clips..there's alot of room in there, so the line doesn't have to be fab'd perfect, but close is good...do a good leak check followed by a full system bleed..
Since your in a rust belt area, chances are you'll have other lines rupturing in the near future..check out your front distribution block ..my brake line replacement started there...
http://www.shoforum.com/showthread.php?t=99487&highlight=abs+brake+line+bundle
As for the tires wearing, mine had same problem..rear wheel hub bearings...changed them both for under $100..takes 5 minutes with the calipers and rotors off...32mm deep socket required..
Hope this helps you out a bit....good luck..!!!
