well while rotating by 3.2 on the engine stand to do rod bearings, i had a little mishap. one of the threaded ears to where the bellhousing goes to the block decidled it wanted to pop off....and i cant find it. i know if i can find it i can get it welded back in, but what if i cant find it? have him weld a chunk of cast onto there and re drill and tap it? put a strap over it and drill/tap some holes into the block so it will hold a bolt and nut? or not even worry about it?
heres what popped off
at least i got the rod bearings and rear main seal/carrier gasket done......
thanks guys
Adam M
thanks guys
Adam M
