hot start problems
evox15
Orlando
When the car is cold it cranks right up on the first try. But after its been driven and goes to operating temperture and is shut off, to restart, I have to crank for a while and give it gas. I don't know if crappy gas is the problem since it starts fine when cold, but I'm not an expert.
Thanks,
Erik
Blast7
Rochester, NY
I saw your other post about having a sluggish SHO. I was wondering if you had checked the fuel pressure yet? Have you run any codes yet? Also, has there been any work done to your SHO recently?
SHOtimer
#2910
Santa Clarita, Ca
Sounds like could be fuel return line check valve..do a search on this..and see if any of the other posts sound similar to what is happening to you.
Doug
evox15
Orlando
haven't done any work on it yet. I am planning on changing the fuel filter and see what happens. I have not check engine lights on now, but I will check for stored fault codes.
Thanks for the help
