Hose routing for the vacuum accumulator
ISHOU
Centennial, CO
Can anybody tell me how the vacuum hoses attach to the vacuum accumulator for the secondaries? I know there are 2 on the canister with one going to the manifold and the other to the solenoid. Does the third hose which comes from a vacuum tee under the IAB route to the solenoid as well? Just want to make sure I have this correct.
I have posted the routing of the vacuum lines twice before, but here it is again for your secondary butterfly opening enjoyment.
"The routing of the secondary butterfly vacuum lines is from the center tap on the intake's rear plenum to the front (forward) tap of the black plastic accumulator tank. From the rear tap of the accumulator to the bottom tap of the solenoid. From the top tap on the solenoid to the "T" fitting under the idle air control valve. From the side post of the "T" to the rear bank secondary vacuum diaphragm valve and from the front post on the "T" to the front bank diaphragm valve."
I hope this helps.
<small>[ July 18, 2003, 03:15 PM: Message edited by: sdpatt ]</small>
naval-avi8or
Chesapeake, VA
Hey scott does the data plate over the radiator on yours and the other years not have the vacuum diagram on it. My 94 does. It sho's all 3 vacuum diagrams.
