ThatShoGuy
the metal tube like things that are in the plenum. do you need thos to make the car run right? mine has them but gonna work on cleaning the plenum and wonder if i need to reinstall them?
thanks!
thanks!
The horns? You may lose a little low end by removing them, but I dont see why you cannot leave them out.
Velocity stacks?
Once you replace the original COPs there will seldom be a problem. The OEM ones from the factory were crap.
Already got an extra set. $25 each from eBay a year or so ago.
You can ohm them but that really only confirms they are dead if the reading is open. I have plenty of used ones....
Look at your very carefully. If they show tiny cracks in the case particularly under the electrical primary plug area then they are probably bad or soon will be.
