Hood prop relocation kit.
ACV1081
Member #187
IA US
Thanks Bob ;) Yep, in the world of strut relocators I'm just about it... well actually a local guy fabs them up, and I sell them for him :salute: Anyways, my paypal is [email protected], same as my email address. With about 300+ sets out there they will get the job done. Price is $45 shipped for the non-plus hoods, and $50 for the fiberglass "plus" jobs. Keep me posted, and look forward to hearing from you. :thumb:
HoustinoJillian
name's JUSTIN
usa
how well do these work on aftermarket hoods? specifically for my the cincy sho cowl hoods, but others with CF etc hoods may be interested.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Also how dificult would it be to install a kit? I'm assuming I'll have to drill, uh, "something".
rudedog
madness sucks
Houston, Tx
no drilling for mine. it was as easy as remove 2 bolts on each side put the relocators on, and put the bolts back in.
ACV1081
Member #187
IA US
This is correct... no modifications needed.
As for the Cincy hoods, we sell them but you can use them at your own risk. The owner of CincySHO has them and I told him the same thing. He's had no problems, but I recommended he try and find a used set of hood struts or somee from another application without quite as much umph since the CF and fiberglass hoods are so much lighter. Hope that helps, and I'm here to serve :salute:
For what it's worth I have relocators on my mutated cincyhood and they're OK too. :shrug:
Adam
HoustinoJillian
name's JUSTIN
usa
yeah i was thinking of searching in the junkyards for struts that don't hold up a normal hood, and then hoping they'd be strong enough for the much lighter hood.
SASHO91
Zoom Zoom
San Antonio,TX
most of the time they are... if it will barely hold up the stock steel hood(50+lbs.) then i'd think it would work pretty good on a lighter hood.... OTH, you may have to replace it sooner than normal... (which means, going back to the JY, :p )
