Hood pins!! where do put them
pitcrew207
SC'D 5.0 Right?
MD-PA
Well im going to put some hood pins on the sho.. just wondering where you guys have put them.... and could show me pics of where the put the posts and how they mounted the top latches....Hoodpins
ive seen someone with those
thanks
joey
1993MTXSHO
Its a Taurus...
Jersey
I took my bumpstops out and drilled holes right there and mounted them:thumb:
rpmshotimeeh
Its SHO_time!
MA
im guessing hes prlly putting em on a c/f hood since they are c/f you know but umm why what would happen if he threw em on a stock hood am i missin sutn here? because my bumpstops are all funky n brokenn and i just hate messin wit em so i was thinkin of throwin these in the stock hood to get it to sit flush unlike how it sits now.
1993MTXSHO
Its a Taurus...
Jersey
SHOspazz92 was getting at is its look wierd on a stock hood. Nothing wrong with doing it other then that.:thumb:
pitcrew207
SC'D 5.0 Right?
MD-PA
these are going on a CF hood...... i was wodering if anyone has pics of the hood open showing where they mounted the pins and how they put them on the hood
SHOMA
Springfield, MA
I can try and get pics in a few of where I put them.. IMO, don't take the bump stops out.... MAke yours operable, or get ones that work, they end up working against/with the hood pins, to keep the hood secure and tight... Mine have worked great and the hood doesn't move around at all..
only problem is, i can almost guarantee the carbon fiber inlay (which matches perfectly initially) will soon after lose its finish, and become a pale white...! I had to take mine off, and polish up the aluminum plate below it...
SHOMA
Springfield, MA
likewise, just get some working bump stops... why ruin the clean look of a stock hood with hood pins?? :shrug:
matasho
bigshotsho93
Beloit Wisconsin
Mikescarblue023
Mikescarblue020
then i removed the bump stops and used the holes that were there for the studs and as for the bump stops i used a black rubber hose for adjusting the height of the hood. it fits great and does not move when going down the road. and i dont have a latch i moved it down so far the hood only reaches the safety catch so if some ****** undoes my hood pins the safety catch is still there so il notice it and pull over i suggest this for anyone else too cause the fiberglass hood just didnt latch like it should so i did this
