hood paint, keep or change?
1slickRED89
Guest
Toledo Ohio
my Sunday project was painting the the hood on my 1994 ATX that has a hood scoop. I painted the underside of the hood with a sound-deadening undercoat and painted the hood scoop and a part of the hood semi-gloss black. I was going for the new Charger R/T look, minus the lettering.
in your opinion...
1. "looks OK, keep it."
2. "paint the entire hood flat back."
3. "you just can't save that monstrousity, give up."
Blackscoop013
JoesSHO
Reality
Sorry. Is that done? Wow.
Certainly not my cup of motoroil... What is with that scoop!?
I don't know if I would have sprayed the underside of the hood with rubberized undercoating either, if that is what you used... Not sure how that stuff reacts to heat/flammability
:oogle:
1slickRED89
Guest
Toledo Ohio
the scoop functional and has to be there, I couldn't think of a better way to it. oh well, either it looks cool or it doesn't.
JoesSHO
Reality
OK, makes sense why it's there.
But stick one of these over it:
6306S
Go Pro Stock! er.. SHO Stock! :biggrin:
Any reason you can't use a tall rear cowl? You should only need to have the opening in a high-pressure zone, and the windshield creates that too...
Mechanicsville MD
hmmm. That was back in 01. No wonder i dont know about it. Was that car ever on a dyno?
You could put one of those huge cowls on it. Kinda like the formula firebird ones.
What was back in '01? The thing only got running recently.
Looks ok. If you get fed up with it, try a vinyl wrap. You can always peel those off. :biggrin:
smokin joe
Milwaukee WI
yeah that was posted in august of 06 i would also like to know of any updates of how things are going on it
1slickRED89
Guest
Toledo Ohio
it ran all last summer and fall. took it apart last November for a tranny upgrade.
the tranny will going in for a rebuild next week. there is a local shop that does rebuilds with shift improver kits and all the goodies. most importantly they didn't laugh at me when I asked if they could build that can hold 300lb/ft (at least through the receiver.) anyway, the project is definitely heating up.
I think I'll just leave the hood as it is, I'm going for a subtle look (as subtle as possible, considering) so I'll just see how it looks outside, when its setting on four tires.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
i need some more pics before i can decide if i like it or not... if you used some bondo/fiberglass and smoothed the scoop into the hood, i think it would look decent... but as far as color i cant tell just from that shot
ty91sho
EVRYDAYHUSTLIN'
st.cloud MN
:) i was bored so i had some fun with this one. you could mix some fiberglass and do something like this
Tyscoop
1slickRED89
Guest
Toledo Ohio
more pics? gotta' love shoforum eye candy.
gtstang1967 said:
looks good you did a good job making it i would paint the hood stock color
you think? I dunno...
for contrast purposes here are two shots before i buggered it:
Sidescoop005
Sidescoop006
more with the black. my camera SUCKS for interior shots, either is blury or its dark, come-on' kodak!!
Blackscoop010
thats nice!!! I can feel that for sure!! I would have to make it out of sheet metal though, all metal.
tasty danish
Missouri
what i think would be cool, although you'd have to fab your own hood, is to put a cowl hood on it but have the cowl come up so that it covers everything but the inlet for the intercooler. so the bottom of the inlet is even with the top of the cowl. in effect you have a sort of "scoop tumor" on top of the cowl. then off the back of the inlet run it raised and even with the top of the inlet so you sort of have a second cowl.
that'd be the shiznittles.
1slickRED89
Guest
Toledo Ohio
so the totals so far. In the interest of impartially, I didn't vote myself. but if I did vote it would probably be option 4.
looks good: 1
paint the hood flat black(or add a other cosmetic feature): 5
give up your done: 2
WTF (not an official option): 2
