ScottyDsntKno
Picked up a 95 ATX SHO a few weeks ago and it needed a brake change. I've done brakes a million times before on my stangs so w/e. Well I have never had so much trouble with brake pads in my life! Those freakin clips are ridiculous first of all, what is the point of them? To stop chatter I guess? At any rate the backs were fine but I went out for a drive after I got all 4 wheels done and the left front started smelling like burning and smoking. So I took it back apart, cleaned everything off, reseated the pads, comressed the caliper again and put it back together. Then the freaking right one started doing the same thing after the second test drive so I took it apart too. Then the left one started overheating AGAIN...
At this point I am wondering wtf is going on? I took the left apart again, made sure those stupid spring/clip things were in the right spot, carefully seated the caliper and tightened it down. Took it for another drive and it seems like the problem might be solved but I'm not sure. The left caliper was still noticibely hotter than the right but that might have been from it overheating before. No smoking or burning this time... I think those wire clips were getting stuck between the caliper and pad. I have half a mind to just cut them off with ***** and say screw it. If they chatter then too bad. It is dark now and I won't have time to mess with this thing till wednesday but are brakes usually THIS much of an issue on these cars? Am I missing something here? I mean this is absolutely ridiculous. I can do the brakes on my cobra in like an hour at most and it never gives me any problems whatsoever.
Wow...
Wow...
