hit 4k rpm secondary twittering?
quikSHOilver
Yamahaized
Indy
When I rev it to 4k and secondary would open and close continously causing bucking or twittering like, when I back off throttle it will idle smooth no problem... I am stratching my head on this one.
quikSHOilver
Yamahaized
Indy
update
I disonnected the secondary vacuum and closed the vacuum port and revved it to 4k same thing it bucks... so I try clean maf with berryman then try again same thing but wont go back to idle only to stay 2k now ha what now? I did unplugged ISC it went down to 800 rpm, plugged back and idle went back normal then rev it same thing bucking then stay at 2k... whatgives?
midnightauto
THE CHOP SHOP
Michigan
not sure on a gen 1-2 but a gen 3 will not free rev the rpm's bounce at the rev limiter
Mr Anonymous
Tire Wall
I just re-read your post. It sounds like you're just hitting the park/neutral rev limiter.
But, if the car isn't stalling when unplugging the IAC then you're still probably looking at a vacuum leak.
quikSHOilver
Yamahaized
Indy
yeah, I recently found out why it was just because of rev limit on atx thur searching the forum so all is well... and as for rough idle, found a silcone coupler wasn't sealing well so replaced the clamp and it purrs now. Thanks guys for ur input!
crystizel
