How much can you mill the sho heads with stock pistons if this is even possible. And how much more compression will it yield? Just wondering since i have to take off my heads to change valve stems seals anyways. Also will the bigger valves make any more power with the stock cams? And maybe porting the heads or do they flow enough as they are stock?
