High Pitch noise after 60k
Dr_Thompson
CT
I recently had a full 60k done and from the serpantine belt/timing belt area its louder now. More highpitched and moves with the Rpms.Im thinking this is because the old bets were loose and the new ones are tighter thus the noise?Any ideas?
Rockledge
Pluggin' away
Connecticut
Probably a tight timing belt. If it doesn't get any better after a couple of weeks "break in" period then you ought to adjust the timing belt tensioner.
Dr_Thompson
CT
yeah i was thinking the belt would have to break in. ill see how it is in a couple weeks of use. thanks
A new timing belt will whine for a while until it gets familiar with the sprockets.
To reset the tension of the 3.0L's timing belt after instalaltion, I have posted the steps several times. If you can't find them let me know.
Dr_Thompson
CT
thanks for the replies guys, ill give it a few weeks and see how it is :thumb:
LJRuddy
Pop lock n drop
Poaceae fields
Yea heres an idea... Take the S/C out! :rofl:
