Here's my new noise from the front end...
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
My rotors still seem fine, I have plenty of pad left on the cobras.... what the **** is this? Stepping on the brake does nothing to make this stop. If anything when I load the drivetrain, (step on the gas) and keep pressure on it, it makes no noise. When coasting or decelerating it is there. Any ideas? Everything seems ok at a glance.
I haven't pulled the rotor and caliper / bracket to check the W.B. because I been stuck working 12 hr days at work, and just too whooped to want to mess with it when I get home.
Th 100 0263
Sounds like it's only in Drive not Reverse? I'd go with Wheel Bearings as well.
I did hear a pickup in the sound when you were in reverse and gassed it just a bit while turning into the parking spot. So wouldn't rule out belt tension/pulley noise either.
I have had a little stone get in the pad and get caught there, and it would grind like the brakes were shot, so something like that is possible.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Well I hear it in reverse sometimes but it's pretty quiet. I noticed today if I turn the wheel to the right, it will also go away. If I coast in a straightline it's noisy. Give it gas it goes away. I almost wonder about the half shafts. Everything is about 30 k old, so nothing should be going out yet.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Left louder yes... turn to the right like I'm switiching lanes.. or loading that side of the suspension or whatever.. it goes away.. as in gone all the way. :)
someguy35
Sci-Fi nut
Virginia
Definitely a wheel bearing. How to tell? Drive on a street at about 35 and start gently swerving from side to side. You will hear it.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Oh I hear it.... just regretting to do the job again. I think I'm going to buy a Napa bearing this time. I wonder if this has anything do with having wider wheels on my car? This bearing seems to have failed pretty fast if you ask me.
dan.delargy
