Help.
John
PA
My car starts up then about 1 or 2 minutes later it just shuts down and wont start up for like 15-30 minutes.. then it repeats itself..
So my 95 mtx spit out codes of an error with the map sensor and i changed it.. didnt help... no other codes are coming up... and im not sure what to change .. i was gonna try swapping my 3.2 DIS Module with mine and see if that might be it but i wasnt sure if they are the same units.. so if someone could tell me if the atx and the mtx DIS modules are the same i would appreciate it .. also any other suggestions on fixing this problem would be Great.. cause im gettin Very Fustrated with the whole matter... :banghd:
Thanks,
John
John
PA
no it is not losing Coolant.. so cps it is then.. how the **** did i end up in this section of the forums.. oh well . oops.
thanks,
John
