Help
SLOWgod
Weeeeeeeeee
Motor still isn’t sitting right too close the rails anybody have any ideas of what it could be ?? 96 trans going into a 98 body
gamefanatic
Barstow, CA
I am assuming you mean getting to close to the lower subframe? If so you want to look at your motor mount.
SLOWgod
Weeeeeeeeee
Rear motor mount is a reinforced one off of shosource trans mount is new, front mount is the same. Everything is the same besides the trans came out of a 96
SLOWgod
Weeeeeeeeee
The alternator pulley is very very close to the passenger frame rail I’m stuck I have no clue
gamefanatic
Barstow, CA
I know all that is close normally. Did you get in there and ensure no bolts are lose? If not take some pictures and maybe we can see something. The only things that hold the position of the engine are the mounts.
SLOWgod
Weeeeeeeeee
I’m not sure the back left side sits too low
SLOWgod
Weeeeeeeeee
Here you can see and is the trans suppose to be over that far thay gap is pretty wide.
gamefanatic
Barstow, CA
Shoot with that battery and airbox removed you've got tons of space.
Seriously though looks about right to me. Your first picture is of the top idler and you have about 1/4 - 1/2 space between it and the wall. Makes loads of fun trying to get your belts on and off if you have them just barely twisted.
Double check your transmission mount is torqued down, but it looks about right to me. I can take pictures of one of mine to show the similarities. Looking at the wires, if things were too far to one side you'd have troubles with that junction connection. There isn't much slack there to be had to begin with.
SLOWgod
Weeeeeeeeee
If you could send pics
gamefanatic
Barstow, CA
Here are a couple. Its about half and inch between the idler bolt and the wall and inch to the idler.
20200708 193950
Since I can't get as far in from the top as you with all the hoses I got in at the bottom and could get just a little more than 2 fingers so just a bit over an inch near the crank.
20200708 193753
Here is just above the transmission.
20200708 193855
Here is the transmission mount which is the point which would hole the engines left and right movement.
20200708 193819
Now that mount connects to the transmission craddle which would need to be bolted all the way to ensure the right amount of gap. You should be able to see this from above to see if your bolts are all the way snug.
20200708 193826
SLOWgod
Weeeeeeeeee
First pic my alternator is almost up against
the frame frail
SLOWgod
Weeeeeeeeee
It’s like my motor is leaving towards the left rear and over
gamefanatic
Barstow, CA
Your mounts are what govern the position of the engine.
1) Check your motor mounts.
2) check the transmission to engine is bolted up right.
3) Check the transmission craddle is mounted correctly.
4) Last, but not least, check your subframe is bolted up correct. If something broke loose here you may need a repair kit. There isn't enough movement to allow more than 1/2" normally once snugged up.
If all those are good, make sure your pullies are snugged down. If they are loose they would be closer. Nothing else would normally cause this.
SLOWgod
Weeeeeeeeee
Engine and trans are good they are bolted up there isn’t a gap
SLOWgod
Weeeeeeeeee
I’m going life the motor and see what happens
SLOWgod
Weeeeeeeeee
Messed up the new mount
