91SHOPLUS
I was looking into putting a turbo on my 91 MTX and was wondering what size turbo would be appropriate. I won't be going above 8 psi.
JDLangevin said:T28, common and just about right for 8 PSI on a 3.0
91SHOPLUS said:So if a T28 is to small what size do I need. A T3 or T4, I have seen a SHO with a hybrid T3/T4 turbo, but was hoping a cheaper turbo would do the job.
flosho said:Would a T3 work if all you wanted was 8psi and not 400+ hp?
91SHOPLUS said:Thanks SHO--ripper for the tip. Also will my stock oil pump handle the additional load, and I want to put an oil cooler in but didnt know if one was avalible for the SHO.
