I am getting ready to upgrade my suspension which is shot.
This week I lost my passenger side inner CV joint, so I had to stop driving my SHO. I need to replace almost every rubber part, shocks (KONIS), and upgrade several parts.
I have been reading through the suspension threads for the past several months, but I an a little confused as to some of the parts and part numbers.
I plan to make my own subframe connectors (they seem to be easy enough to make and I have the tools). I plan to use the 2 square 1" tubes welded together.
I plan to keep my stock springs and install Koni inserts.
I guess that I should replace the Front and Rear strut bearings and Upper Strut Mounts.
My Swaybar end links are shot, so are my Steering Rod endlinks.
I have net even looked under my rear end, but I am sure that I will have to replace everything in there too.
I know that some of you guys have already done this, and probably have a recipt with the part numbers for all these parts.
Could you post the parts with the part numbers that I need, to help me with my shopping list.
I plan to takle the front end first since I have to replace the CV joint. Who makes a good replacement complete half shaft with CV joints?
I prefer to go with performance parts, rather than cheap replacements, but I am not interested in a race car ride. I would like to set my SHO up as a sporty "street ride".
Thanks.
Jose
Thanks.
Jose
