I'm in the process of changing out the SFB's and am having a problem removing the rear ones. The front ones came out real easy, but it seems the rears have been fused to the sub frame. Does anyone have any hints for removing the rear SFB's. I also cut the holes and am doing the recall stuff myself.
Also, will I have to grind out some of the rear hole to fit in aluminum SFB's? There seems to be some sort of metal ****** around the hole. I have done a search and read many posts on the SFB changeout procedure, but none mention this ****** thing. I also read the writeup at Kurtmetros.com and that didn't mention them either.
Thanks in advance for any help!!!
