Help with no-start problem
SHO_Stop'r
Portland
Ok I was driving fine for 2 days then I turn the car off. 10 mins later. SHO no go. Tryed getting a jump, Nope. Tryed filling it with gas, Nope. So I tow it home. I try to bump start it. No such luck. So here I sit. I try and run the codes. The check engine light is dim. All others are fine. Just the CE light is dimm and when i jump the wires it doesnt do anything. No fan turn on NO CODES. :( I tryed listne for the fuel pump cant hear it. Tryed jumping it. cant hear it. So I dont want to replace it if its not bad. WHAT DO I DO ? Why would it not run the codes ? The car cranks but no start.
Thnx
Evan
P.S. Happy Birthday to 91tauriSHO . scott turned 21 today !!! :cheers:
Bizzy
It sounds like your computer is not getting full ground or power. Check the connection of the ground wire near your battery that connects to the fender firewall, check the connector just a few inches up line from that. Make sure that the contacts are clean and that the connection is tight.
Check your battery terminals, make sure that they are tight and that the wires are free from crud. If you have aftermarket lugs make sure that the connection holding them in them is tight.
There is also a ground strap that goes from the back of the intake often on the rear passenger side support to the back firewall. Make sure that connection is tight.
Those would be the first places to look for problems.
Edit: Also check the voltage across the battery terminals to make sure that the battery is not low.
91taurisho
my house, CO
Thanks Evan!:thumb: I'm still trying to come up with something more than what Bizzy said(good job Biz! ;) ). If I think of anything, I'll post it here or call ya.
Tmade
Cincinnati, Ohio
Ok, here is a rookie question. I see a lot of people mentioning that they ran the codes.
How do you do that? Do you need a special tool to hook up to the car to check them?
Thanks,
Doug
91taurisho
my house, CO
Ok, first off, My name is spelled SCOTT And her name is spelled RACHAEL. :p When I told her you said that, she got this wierd grin on her face. You know the one. It's almost identical to the one Megan makes when I'm... Nevermind... :evil_gri:
SHO_Stop'r
Portland
Nah I dont know what the smile looks like.. all I ever saw was the top of her head ?? :squint:
91taurisho
my house, CO
DHMag said:
thats just wrong...:nono:
thats why i call every girl "babe." dont have to worry about calling out the wrong name or spelling it wrong. :p
as for the prob at hand..it sounds familiar.....Bizzy would be your best teacher
Dale, That's why the last 3 girls I've been with were Rachel or Rachael... :D
I also must ask what you mean about Bizzy being the best teacher? :eek: I sincerely hope you mean about Evan's problem with the car and not what you quoted me on! That would be Slandering Beth's good name! Unless it was true of course... :D
Evan, Read below! :p
Jason, I agree whole-heartedly! :snicker:
SHO_Stop'r
Portland
well im gonna go to sleep... tell racheal not to wait up tonight.. :D tommrow I drop the other tranny and install this clutch and tranny hopefully :bonk: so id say... expect a few phone calls. :thumb:
AREA 91
PA SHO SHOP
Area 91
We're going to ****? That's where all the cool people will be anyway! Who wants to ride in with me? :finger: :evil_gri:
