help with my 89
slimsho2469
madison, wisconsin
i have an 89 mtx and when i originally bought it i had to replace the valve cover gaskets cause i had about a shot glass of oil in each plug tunnel. while doing so i changed the plugs but didnt have enough money to get the new plug wires. since getting it back together it does run better but it will die on me from time to time when i puch the clutch in but only when coming to a stop for example. always starts back up but its really anoying. would the wires possibly being fouled cause this problem? someone also told me they thought it sounded like it was missing but i dont here it, maybe im nuts
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
What ahppens when it dies? Could be IAB. I would guess your wires are bad though.
slimsho2469
madison, wisconsin
what do u mean what happens? ill be drivin and the light turns red so i go from say 2500 to clutch and the rpms just drop steady from 2500 to like 500 then the oil pressure light and dead. i just start it up again, sometimes it cranks for a llittle bit before it'll fire but usually fires back up almost instantly.
slimsho2469
madison, wisconsin
i have had the codes run and it threw a ignition code but i cant find the sheet or remember what the exact number was. also threw a code for the vehicle speed sensor but im more worried about it runnin right for now
red89mtx
Guest
kenosha area wi
i drove the car today its missing badly like on 3 cylinders clutch seems fine think he needs wires ot start with other wise cats clogged maybe
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
the VSS is the cause of your stalling issue when clutching while rolling, I had a member here with the same problem, stalling when downshifting and such, told him to replace the VSS and the problem dissapeared.
The VSS tells the computer that you are moving and keeps the RPMs up a little bit to compensate, if there is no VSS signal, then the computer does not know that you are moving and will drop the idle right down, causing a stalling condition
slimsho2469
madison, wisconsin
by no means am i trying to get out of replacing the vss but could it be? it doesnt stall everytime or even every time i drive it. i did quite a bit of drivin today and it didnt happen once. i need to replace the vss anyways because it doesnt work but it just seems odd if it was that i would think it would stall alot more.
Mels
SHOVELHEAD
Brookfield CT
Does your cruise control work?
*EDIT* Never mind, I see you're planning on replacing the VSS anyway. Mine hasn't stalled like yours does now since replacing the VSS.
The good thing is on an '89 or any of the mtx cars the vss isn't too hard to change. atx vss= yuck
slimsho2469
madison, wisconsin
got a new vss and put it in the yesterday, noticeable difference without the new wires, but wires are comin as we speak, got the accel 8mm i do believe and got some autolite double platinums for them. anyone have any experience with unclogging cats in these cars?
