PuckHead
www.mn-mason.org
Hey guys, gotta quick question for the masses.
The idler pulley on my '93 ATX is creating quite the 'whine' and it really needs to be replaced. I've had it looked at and the concensus matches my own opinion. The whine does not change with any movement of the steering, ONLY with engine RPM's. Put a mechanics stethoscope on it, and hoo-boy does she whine!
Now for the question(s):
Does anyone have a part number or dimensions for this pulley? I went to my local parts place (that is usually very reliable; Only reason I go there) and the ones that they had listed, were definately NOT the right parts.
Secondly, how big of a job is it to change out the pulley?
By the looks of it, it seems pretty straight forward. Remove the battery, remove the serpentine belt by releasing tension on the tensioner pulley by turning it clockwise with a 14mm socket, remove the pulley with a 14mm socket, and re-install the new one. Right? Wrong? Need Info!
Thanks in advance!
Later!
Thanks in advance!
Later!
D'oh! 'Scuse me while I pull my foot out of my mouf.
