Glenn W
My 92 was making a smelly drip onto the catalitic converter and after crawling under to see I found coolant running down around the crank damper onto the pipe and burning. Time for a water pump It would seem.I have a puller to remove the crank damper but was wondering what do I need to re-install it?Also I guess it would be wise to replace the timing belt too while I have it apart(78,000 miles)Do I need anything other than the belt for this job,parts wise?
Once again thanks all for your help.
Glenn
Glenn
