Help w/ man trans filler plug?
SHOYourYama
Albuquerque, NM
Ford discontinued this item, or so they say. Mine is stripped on, hopefully in can be removed once more and then replaced.
Ishodu
Well When I had mine out I noticed it looked exactly like a plug for Ridged Conduit. They both even use the 3/8 ratchet. But if you get the size of the thread and match it to a pipe plug you should be all set. Except that the tool to remove and tighten the plug may change.
<small>[ January 21, 2003, 07:14 PM: Message edited by: ishodu ]</small>
