Justin101
It's A SHO Thing
i just did the codes check and this is what i came up with, can some of you help find out what i should do to fix them! thx all!!!!
Key On Engine Off
176 Oxygen sensor not switching-system is or was lean Left or FrontHO22SSS
219 SPOUT circuit failure, timing defaulted to 10 degrees
Key On Engine Running
136 Oxygen sensor not switching/system lean Left or Front HO2S
538 System did not receive "goose" test
536 Brake On Off open or shorted to ground - BOO
Please tell me this wont be expensive!!!!!!!
i dont know much about these codes so PLEASE HELP!!!!
Key On Engine Off
