help requested on stuck door.
JOSHM
Pipe Creek, Texas
Hello all,
My right rear door is stuck shut on my 91 MTX. I can hear the door lock actuator clicking when attempting to lock/unlock but the manual lock rod can not be moved - seems to be frozen in place. I have removed the rear seat to gain better access to the door panel. I have removed all door panel fasteners except the one from the side which generally requires that the door be open to remove. So until I get the door panel removed further diagnosis is not possible. Thanks in advance for any help you may be able to provide.
Bizzy
Sounds familiar, must be the curse of the 91's. My outside door handle is broken inside the door and I had the child safety lock on so it can't be opened from the inside. :rolleyes:
