I recieved the stud from Fred(thanks a lot), and I started around 12pm hoping my stud at least snapped half way. But the worst happened, it broke flush with the block and found a "regular" drill wont work to tap it out.
Now will I be able to access the broken stud with one of the 90degree angle drills? Or could a regular stud extractor work?
One more thing my A/C belt tensioner came out easy with the 5mm hex, but the rear(waterpump) tensioner slipped with the 5mm and its stipped a bit up top. Could I get a 5.5mm or 6mm hex and hammer it in to make the hole larger? I already removed it by taking out the surrounding 3bolts holding onto the block.
