Help!! Procedure needed-
mclarida
Orlando, Fl.
I am in need of a the procedure to change out my vss in my 93 atx. I know that it is hard as he** but it needs it. Any suggestions will help-any pictures will help-I just do not want to go in blind-
Mike
AREA 91
PA SHO SHOP
Area 91
1/4 inch drive rachet and socket. You might want to use a universal swivel as well. Remove the Y pipe. You do NOT need to remove the rear exhaust manifold.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
Just remove the manifold from the head. Take the bolts out of the y-pipe, then head, egr tube, egr, then romove the manifold. that will give you access to the VSS. Its not as bad as you would think. It only took me about an hour with hand tools to do it.
mclarida
Orlando, Fl.
2 methods-which is the better cup of joe?- I would rather not remove the manifold from the head. Y-pipe removal with swivel? -
M
