HELP ME
Monterusto
NY NY
MY CAR HAS BEEN RUNNING LIKE S%*& FOR A WHILE NOW WITH SOME OTHER PROBLEMS I STILL CANT FIGURE OUT. IVE POSTED BEFORE RECENTLY AND IM STILL NOT GETTING ANYWHERE. I JUST RAN CODES TODAY. KOEO 11/24,21,24/41,66,91 KOER 21,24. I RECENTLY CHANGED BOTH 02 SENSORS. AND TODAY I WENT TO AUTOZONE AND TRIED ON A NEW MAF AND NOTHING WAS DIFFERENT. BESIDES THE CODE FOR THE MAF I CHANGED BECAUSE SINCE I GOT THE CAR 2 YRS AGO I NOTICED A BRASS NEEDLE WHICH SPANNED THE MAF ON THE INSIDE. I DONT REALLY HALLUCINATE AND THE NEW ONE DIDNT HAVE IT. AFTER MY CAR STARTED RUNNING SH%#) I STARTED LOOKING TO FIX IT AND 2 MONTHS INTO THIS I WENT TO SPRAY THE THROTTLE BODY CLEAN AND NOTICED IT WASNT THERE. IVE BEEN GETTING POPPING OUT OF MY AIRBOX WHEN I FORCE THE CAR HARD. TALK TO ME
Bizzy
Did you clear the codes from the first time? If not you should do so. Double check that you got the proper replacement 02 sensors. When you replace the MAF sensor or 02 sensors you should always reset the idle so that the car can learn that it's got new stuff on it.
The MAF sensor should have 2 filaments in it. If it doesn't have 2 then you've got the wrong replacement sensor. It is possible when you cleaned your old one that it was already gone, or perhaps it came out when you were cleaning it. This would present a problem for your computer as it won't have the correct input to base adjustments on.
Just an FYI, when you post you really should not type in all caps, most of the guys will think you're yelling at them as that's what all caps means when communicating via the internet. wink I, however, don't scare off that easily. :p
<small>[ January 03, 2004, 03:30 PM: Message edited by: Bizzy ]</small>
