Help me answer some SHO questions?
SHOman24v
Fresno
about a year ago i got a 1990 SHO with only 63K miles. this car was all orignal, it still had its stock clutch even its in almost perfect condition for its age. its been a great car for me. i put flowmaster exhuast on and centerforce clutch on it. i need some questions to be answered for me. it now has 78K and runs great but i know it needs matience, can anyone tell me what i need to do to make it run even better remember.....its all orignal nothing has been replaced, and also im looking for some 1991 slicers for around $150
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Well the 60k would be a good place to start. You can check the SHOShop or SHOTimes for info on that. That consists of plugs, wires, valve adjustment, fuel injector cleaner, and other parts. You might also want to replace the air filter with a K&N and remove the silencer cone. This will add a little power and your car wil sound mch better. Also might want to replce the rubber intake hoses. Mine are cracking and should be replaced. This will create phantome leaks. This is more costly but will help is to have your intake manifold port and polished. They can get dirty and when this is done it will add around 10hp. Beyond that you will start getting into performance stuff.
