Help installing radio
RABMotorsports
Reading Pa
I bought the harness to install my CD player. It has three harnesses. Does the on that is connected on both ends go back where the amp is? Does anyone have a pic of where it goes? Thanks
BlackOnBlackATX
Dutchess County, NY
i can take a pic for you in the daylight tommorow but yeah, the double ended cable goes where the amp is in the back, its all real easy, once you pull out the radio the rest is 1-2-3. lemme know if you need more help man.
Detenator
Rockland, NY
That double ended harness bypasses the amp that sits in the trunk. It lets signal go straight from the cd player to the speakers without going into the amp.
