Hi all, I need some help with my 95 MTX. Idle is very erratic; sometimes normal, sometimes a bit too low and rough, often stuck at about 1400, sometimes stuck at 2k, sometimes races to 3500 when eatc (a/c or def) is ON. A few times while driving, the engine power fell flat on its face while engaging clutch from stop or from 1st to 2nd. (Engine did not die however).
Only code was 122, TPS (stored), replaced TPS, same problem - now the codes are 121 and 122.
Could this be a CID, VSS, or maybe a CCRM problem? I am confused as to why the EATC changes the strange idle behavior.
Any help appreciated.
Thanks,
Thanks,
