I have a 93 SHO ATX with almost 200 K on it. I decided to remove the intake so I could fix a problem with oil in the plugwells. I fixed that problem, and cleaned all the junk out of the intake. Now it is time to reassemble and the problems have started. First, I broke a small hose in the back that connects to a small port in the back. Then I broke a bolt that holds on a part in the back of the engine on the right hand side as you look at the motor just to the left of the brake fluid reservior. It says on E9DE-9D460-CDA it and bolts to the intake. There is a hose clamped to the bottom of it. Also, some tubing pushes on to it as well. I need to know what this part is called and where I could get the bolts for it. I don't have them for comparison, as they broke off and fell in the engine, I still haven't found them. Besides all of that, the SHO only runs at 4k RPMs now and when you rev it up, it sounds like the rim limiter is on. It also stalls out now. Could this be the cleaners that I used? Any help, advice or part numbers will be appreciated!
