Glenn W
Tearing into the engine for the 60 k overhaul I am down to the crank damper and it wont come loose I have used liquid wrench and my electric 1/2" impact drill but it wont budge! Any suggestions?
I had the same problem. What I did was put a long pipe on the end of the ratchet to get leverage. Also I had another person in the car that put the car in gear and stepped on the brake so the motor did not turn. Or you can do what my friend did with his SHO, he wedged a wrench in place and cranked the motor once(I don't recommend doing it this way).Glenn W:
