slapnpop
So, the '95 ATX went dead Friday afternoon. Like someone hit a **** switch, engine just stops. All other electronics are working fine, and the fuel rail is pressurizing. I got no spark.
Tried to pull codes, but get a 1 1 1 in Key on Engine off, but can't start the engine to run full codes. Come back an hour later, and she starts, so I run the full codes and don't get anything concerning (only EGR valve failed to respond, I need to clean the intake).
I figure the CPS is due, so I install one Saturday morning. Car starts up and runs fine. I figure problem solved.
Then comes this afternoon (Tuesday), and I get a call that the car died again on the wife's way home from work. Same deal, KOEO yeilds a 1 1 1. This time waiting doesn't get a restart, so I have her towed home.
I've looked over all the connections I touched, and it's all good. I assume now that the problem was not the CPS, but something else. Any way to tell without the engine running? I don't want to just start replacing things on a whim.
