Heater core labor?
89SHOduff
Attleboro, Ma.
Damn. eek! that much. You have to take the dash board apart right? If it is 10 hours book I sure as **** ain't bringin it to a shop. Is it really hard to do? I'm somewhat inclined but not a ******** mechanic like many here.
It's alot of work. Plan on blocking 2 or 3 days. If you catch on quick maybe an early start on Sat. and finish mid Sunday. Paying someone else- big bucks. Probably anywhere from $800+ with parts.
DougLee25
Hatboro
I started at 9 in the morning and finished by 4:30 with a half hour lunch. It definetely is labor intensive. The whole dash has to come out. You'll have about 100 screws to put back in. You need to disconnect the AC lines on the fire wall too. Get the system evacuated first. Use one of those screw guns with a socket attachment to speed up the process. Take your time and you'll be fine.
Doug
sleepa
Wisconsin
my friend (flosho) took his to the shop and it took bout 8 hrs and his dash is still kinda loose!! if u can do it, i suggest doing it urself!!
89SHOduff
Attleboro, Ma.
if there is a page that would go through all the steps I think I could do it. If there is could someone maybe put the go to highlight on it so I could try it out. thanks alot. dont want to pay $800 + for just a heater core, even though the mornings are starting to suck now (40's) eek! . It's a gen. 1 if it matters.
DougLee25
Hatboro
I got a price of $550 from start to finish. Seems ashame that the actual part was only like 40 bucks, hence why I did it myself.
Doug
projectSHO89
SHOless In St L
He's in Massachusetts, I think he'll need it! :D
Not everyone can be lucky enough to have the weather in Orlando. :D
Steve
89SHOduff
Attleboro, Ma.
already bypassed it about 3 months ago. thats why I need to put it in now before it gets to be like 10 degrees outside eek! . It would take alot of B@lls to go all winter without heat. I sure as **** aint payin $800 to have heat for just the winter. I'd have to live in Alaska to pay that much. I just hope everything goes well if I do it myself. thumbs_u
Derek
Saugus,MA
Im in your same spot. I got an estimate for $500 alot better than what I'm reading I guess. I plan on doing mine... Its funny the heater core only cost $21.00... :rolleyes:
Chrisssssssss
vancouver, BC, canada
I am doing ine right now, and those links that were posted earlier, uh... I don't think that it looked like that in the pictures, but then again I could be wrong... Is the SHO different than the reg taurus for heater core? just curoius.
