Heads up display H.U.D.
S
slosho
Guest
I was wondering if anybody has any opinions on this as I was looking into buying one. They have them aftermarket. www.defi-shop.com
95' ATX Opal Frost
Cone Filter W/ heat shield
TB coolant Bypass
Fog light mod
Reverse light mod
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
[This message has been edited by slosho (edited 10-26-2001).]
SnoSho
Circle Pines, MN, USA
I like the HUD you found there man I would just like the MPH and Tach at the same time. One that note. Anyone reading this know if I could put in a HUD from a GM product IE GTP, Buick, or Old C.Supreme. I was looking at the Junkyard for parts from my budies Monte and noticed them. Anyone know if they wire to the trans or the computer and beyond that if it would even read from a Ford?
Tim M.
RStalveyARFF
too many shos
Georgetown, MA
That thing is cool. If you could know your speed over 140, not that I do it or condone it
and having it right in front of you, that'd be awesome!
SHOed_up
Ann Arbor, Michigan
Man, I really like that sports VSD one. I'm going to have to find out how much they cost. As my luck will have it it will probably be much more than I can afford.
EDIT:Surprisingly it's not nearly as much as I feared, only $215 which isn't bad when you consider white faced gauges are $120.
[This message has been edited by SHOed_up (edited 10-27-2001).]
SHOmuchFUN
Hinesburg, Vt., USA
I think it's kind of TACHy
No pun intended
Erik Engstrom
1995 ATX SHO
Shoside1
Eibach Springs/KYB struts
17" TSW REVOs
TOYO PROXES tires
PIAA 1900X platinum foglights
Pilot Motorsports Stainless mufflers w/
custom bent exhaust.
CUSTOM RACTIVE Superflow Intake
White faced guages
Eclipse/MTX/Audiobahn stereo
"SHODOWN" license plate
15% tint
TAURUS SHO window banner
Few stickers to add 15HP
WWW.NESHOC.com :) OR
http://SHOmuchFUN.freeservers.com
ShoGuy93
Yes I Have Blue Rims
New Palestine, Indiana
LOOks good to me.
Brad
93 Sliver ATX
SS cold air snorkel with k&n fliter, superchip, flowmasters 40 series, pp y-pipe, Performance Friction Carbon Metallic Brake pads, Pilot fog lights, Intake Painted sliver, Kenwood excelon cd player and 10 dics changer. 5% tint all around! Ford Motorsports decal on windsheild, and Blue sho reflective lettering on the body.Blue, Yamaha inside stickers. Blue, SHOForum.com sticker on back window. Ford emblems on my back triangle window with racing decal under it. So it says Ford Racing!! Indy Tags: SHODU
Looking for a Sliver or Black MTX with low miles!!!
SnoSho
Any one out there with a GTP know how the lines run for the HUD and if I could sneak one into a SHO? I can't get it out of my head I know the radio HUD would be lost and that sucks but if it is compatable should be able to get the Tach and Spd wired in and mounted, even if I have to buy a junkyard dash to test it on
Tim M.
Slo-Sho
It wasn't me!
Crossroads, CNY
Can anyone get me a diagram for the EEC-IV main wiring harness? I want to find out which wire I have to tap. Thanx.
SHO92
Upper Freehold, NJ
The GM huds are run off of their PCM. If you have a GM without HUD and you want to add it, you need the dash harness and the PCM from the car you got the HUD from. The defi might be cool, but I don't know if the VSS that is on the SHO will work. The defi model requires a speedo output wire for the speed to work. The tach shouldn't be a problem though.
Slo-Sho
It wasn't me!
Crossroads, CNY
The VSS is an electrical sender, it sends pulses to the PCM, I just need to know which wire it is at the main harness. I want to contain all the electrical within the passenger cabin.
