Headlights Galore! *Projectors inside*
intimdatr
Got Cams?
Jefferson City, Missouri
Some of you all I'm sure have been following my headlight 'testing' over the past year or so. I finally jumped up to a pair of the big boys. FX-R 3.0s. For those that don't know these are about the best aftermarket for the money projector out there. I'm using the Morimoto XB35 5000k bulbs that are built for 55w ballast and man are they bright. (I'll get some light output pictures this weekend)
Here a few pictures, I apologizes for them being iPhone quality.
Here's the difference in my old projectors and the new ones.
Left is Morimoto Mini H1s. Worked well but i burnt the chrome off the bowls with 55w ballast. Oops. :evilgrin: Lol
1656155 10151929329364607 5986272 n zps31cbae2b
1891250 10151929329194607 914742649 n zps13382ca0
These are the size of the holes i had to cut, then i ended up cutting out a crap load more plastic to end up getting them to fit. These things are huge. used a 3in hole saw to get these holes
1610079 10151929329534607 1892044922 n zpsf6315fce
1604448 10151929329444607 1767685033 n zpsea394e12
Here you can kinda see how cutting looks, ain't purdy..
1656074 10151929330034607 933175252 n zpse014aa12
1655963 10151929329939607 1256580260 n zpsc7208891
What the end product is gonna look like minus the shrouds which i haven't picked out yet. They're going to have to be small to fit in there with the rest of the projector.
1795774 10151929329579607 2142517700 n zps7c31c5ae
1901417 10151929329749607 1178865451 n zps4292e38d
EL SHO
Taco Manager
Monterrey, Mexico
Really impresive work!
Too bad there are not clear headlights for our Gen2 cars. Do you think that the clear covers from SHO Source would last if used as permanet cover?
Patent this design and sell it for good money ;)
intimdatr
Got Cams?
Ive been using the SHOsoruce GTS headlight covers for both my 1st gen and 2nd gen setups. They help up pretty well. and kept enough of the water and debris out of the housing. Never had any issues with them.
sperold
Last to Know
Thanks for sharing all the great information on projector headlights. I still know nothing about them (like there is a shutter that drops down to give you low beams???), but I do know that all my SHOs have poor headlights, and it takes away from the quality of the experience.
Does that reflective back of the housing do any good with a projector headlight?
My opinion is there is a semi-crazy look to that black dot in the center of the rectangular housing. Can that be improved?
Great project.
intimdatr
Got Cams?
Great project.
Yes there is a shutter that is controlled by a magnet that moves a shutter up and down for Hi/lo beam. Pretty cool idea makes for instant transitions between the 2.
The reflective part that that is important to the projector is all contained inside the projector itself. All the chrome inside the headlight housing is just there this point because it looks cool. Lol
Not quite sure what you mean here?
sperold
Last to Know
If the original covers (that have a cut diamond patterned surface) were used, how big of a hole would have to be cut in the patterned part (to not affect the projector cone of light coming out). That way you see less of the projector body.
Would a special harness need to be installed?
intimdatr
Got Cams?
It doesn't work at all. I held one up in front one time the light pattern was completely useless.
TO HIDs in general you need a harness that designed for it that has a relay in it to run the HI/LO function. A new harness is always nice too since ours isn't know for being great.
sperold
Last to Know
I was thinking more like you would cut a hole in the cut diamond surface and put a clear insert in the outer casing. The cone of light from the projector would shine out through the clear section that was added.
intimdatr
Got Cams?
Ahh! The hole would have to be pretty pig. I could look more this weekend about how but the hole would need to be. I have an idea of about 4 inches, if not more. However i think it would look a little funny. Lol
I shall research more when i get home. I made need another set of housing... :munch:
sperold
Last to Know
Great project.
I always wondered why companies improved the rear lights of Gen 2 cars (when there was no issue with the originals); and left the headlights out of the improvement plans(which need improvement).
I looked on the webpage for Morimoto, and got a partial answer. Without knowing what harness to choose, I could not come up with a firm price, but it looks like it might be expensive.
Do you have an idea of costs.... and how would the high/low change occur.
Would it work with the existing multi-function switch on the column?
Again, Great Project.
dohcsable
Gold Calipers>*
Indiana
Why? Just dismantle the housings, use two to make a plaster mold and then make concrete headlight replica's......then build a jig to put plastic in your oven. Once hot, push the hot plastic down over the concrete replicas. BOOM, clear lenses that after some trimming can be glued to the factory housings. ;)
intimdatr
Got Cams?
Great project.
You would use a 9007 harnesses brand doesnt make a huge difference but I'm using a DDM tuning harness. Harness arent super cheap but its one of the cheaper parts of the job.
Total cost? its gonna be a lot. To do it yourself is gonna be around 500, easy. If were to make sets to sell its gonna be more.
No messing with the multi function switch, the harnesses join up with the stock harness and and uses relays to do the hi/lo
Thats the plan. I have started that for the 2nd gens.I need to do it for the 1st.
