Headlight removal??
New to the SHO
PopGoesTheWeasel
portland
just like the title says how do you remove the headlights on a gen 1 from the headlight assembly? thanks
JTSHO
NO SHO
winston-salem,nc
if you have the header panel out, you will see 3 headlight clips to take off, you will need a snap ring tool and a pair of pliers. use the snap ring tool to release the clips and use the pliers at the same time to wiggle them off. pretty easy once you get the hang off it.
mosho93
Well-Known Member
Wausau, WI
What he said! First couple will be a bugger but after that, it's a breeze!
