Huntervf
Bored now
Ok, here's the symptoms:
93 ATX: all lights function a-ok with the autolamp turned on. However, turn the autolamp off and ONLY the headlights will turn on with the switch. Turn the switch to parking lamps and nothing at all, no markers, no interior, no fogs, but the warning chime will still sound. Turn the switch to headlights and only the headlights come on. No interior lights, no marker lights, no fog lights, no tail lights, only headlights.
Leave the switch alone and engage autolamp however, and everything works as it should, provided it's dark enough for the autolamp to engage.
Here's what I know:
In the past year there have been a couple times where this same situation has happened, but it mysteriously fixed itself within a minute or so each time. It happened so infrequently that I didn't put much thought into it.
The car has had an intermittent MFS since I got it two years ago. For the most part it's been fine, however sometimes when engaging the turn signals they won't blink unless you wiggle the stalk. High-beam operation is fine. Wiper delay only works on the quickest setting.
Here's what I've done:
I replaced the headlight switch about a year ago, the old one was getting hot for some reason when the switch was turned on. With the replacement switch (salvaged from an unknown year SHO) the heat issue went away and everything was working fine.
Foglight mod.
Fishtank lamps.
In searching I saw reference to a bad MFS causing problems, but none of the symptoms covered everything I have going on. I have not checked fuses at this point... figured before I start looking I'd see what the forum has to say about it.
So, what say you? Bad MFS? Another bad headlight switch? Or some other goofy problem I have no idea about?
TIA
Here's what I know:
Foglight mod.
Fishtank lamps.
TIA
