Head light cover question
SHOLUV
TX
The headlight covers on my 97 are dull, old, yellow, scratched. How do I get them to look clearer and newer or do I need to get new ones, and if so, where can I find them? IMO, they take away from the looks of the car the way they look now. Thanks!
wuzzzer
MN Moderator
St Cloud, Minnesota
I used a plastic polish in a yellow bottle that I got at Wal-Mart. Using two different rags and a lot of elbow grease and mine looked quite a bit better.
It will need to be redone every 6 months or so.
SHOgun_it
Michigan
Yeah, I have the same problem. Only on one though....
SHOLUV
TX
Thanks, Wuzzer. I'll go to Wal-Mart today and look for some.
SHOLUV
TX
I wonder why only one and not both? Is one of them new?
Ford headlights are by far the best. Then TYC. I've also had Eagle Eye and DEPO. Both of them are junk.
I got the Ford one and TYC one nearly at the same time in 2001. The TYC one is starting to yellow and the Ford one is still pretty clear though scratched and pitted. Tried some Blue Magic plastic polish and it worked OK but they said to use some of their Blue Magic metal polish first and I would agree.
There are two different headlights too. '96 - June '98 and then those after then. The early ones have a silver interior and the later ones are black inside.
www.1aauto.com has a good deal but do not buy any unless you know the manufacturer of the lamp. Insist on TYC who is a Japanese OEM supplier if not going with OEM.
Other things to beware of with the headlights.
When removing them there is a small metal piece that holds the black gasket around the headlight and it is at the bottom center of the headlight. When pulling the headlight out be sure to lift up slightly so it will not scratch the bumper paint.
Also on the OEM Ford ones the single tab that bolts down to the inner radiator support, and is pointing to wards the other headlight, will break off easily and gets worse with time. Do not over tighten. The TYC one has not done this but three out of three Ford ones have on my car.
JoesSHO
Reality
Headlights?
I used 3M "Finish Restorer" on mine, and it removed everything but some of the small pits caused by rocks, etc... Also available at WalMart (in a smaller black bottle) and you can use it on the rest of the car, too... Worked way better than the KIT stuff- at least for me...
This is before:
This is after: (pics after one 30 second application- I ended up doing three)
SHOLUV
TX
Paul,
Thank you for all the info. You are a wealth of information, my friend!
JoesSho,
You can really see the difference! They look so much clearer. Thanks!l
