RinalStar93atx
I am confused about this whole head gasket problem for 3.2 liter SHO's. They are in limited supply and thus very expensive. In a search I was doing on my own and from what I gathered I could just take a set of 3.0 heads and stick them on a 3.2 because they are interchangeable and have the exact same combustion chamber size. You would also get the benefit of having the mtx intake cams and be slightly better. I only ask because I recently came across a cheap 3.0 engine and scooped it up. So if you could put a 3.0 head on a 3.2 motor, then why not use a significantly cheaper 3.0 head gasket as well. I must be missing something somewhere. Someone please set the story straight.
