wouldn't that defeat the purpose?
Also...just random thoughts here.....
As the SHO intake and head design are super-effecient anyways, seeing as how a "normal" head porting job yeilds very little gains, what's the purpose to all this aside from creating what looks like more turbulence going into the head port? I mean, all that air's gonna stack up seeing as how I don't see any enlarged valves or more lift....unless a set of cams and oversized valves are in the works, which, considering you're broke, I don't see happening...
I am simply trying ideas. How can I justifie big cams and valves with no data? I wouldn't touch those areas anyway. The stock cams are excellent, and the head works just fine. I can port all day long for free, and try ideas out. Head is certianly good stock, but cleaning up certainly wont hurt. Plus I will build my car to my specs. I don't ask why you did what you did to your car, and I really dont care for that matter.
Besides your passage above tells me you don't really know what your talking about anyway. The port should start large and reduce in size to accelerate the air. With the larger initial opening I am compressing more air. Never mind the purpose of the dual stage intake, it doesn't matter, and doesn't apply to my build because you don't even know my build, so stop thinking you do.
How many cylinder heads do you see with middle dividers? Not many...
The S2000 has a very remarkable head and it doesn't have a single divider...
Once again your probably thinking about the dual stage intake, toss that idea in the trash, it doesn't matter you still don't know my intentions...
Point is...I do alot of reading, live and breath car stuff. I am open minded to opinions and like sharing information openly. You may not allways agree with me, but your not required too. I base everything off examples around me, my own expereince, and things I read....
