HD brake info.
1slickRED89
Guest
Toledo Ohio
hey all, is there a website that has the matenince information on the wilwood brake kit? i would like to know what all is involed in cleaning the calipers, i read about soapy water and a tooth brush but i would like to know more about it. any experience or tips?
Thanks,
Corey
TwiceSHOwn
Atlanta, Ga
Well i live in NC so not alot of salt etc but pretty much what i did was unbolt the caliper cleaned it with brake cleaner and a tooth brush, used the speed bleeder and got fresh fluid in it and wiped down the outter case. Thats it...
93 Silver ATX 57K
LPM
80MM MAF
Y Pipe
Eibach + Tokikos
Front and Rear STBs
Cold air snorkel
TCE SHO stopper brakes
Recovering from its 60K...sigh
1slickRED89
Guest
Toledo Ohio
Twice, thanks for the reply and the tip. have you ever had to replace a rotor. i was thinking about turning the rotors, but don't want to make them unsafe
Thanks again,
Corey
[This message has been edited by 1slickRED89 (edited 12-09-2001).]
1slickRED89
Guest
Toledo Ohio
i have another question. since the area of the pistons is greater with superlite calipers than the stock ones would any increase in master cylender piston diameter be nessisary to prevent a squishy pedal?
twice, whats the pedal like on your car?
thanks
Corey,
89SHO
