car is hard to start, if i crank it maybe 3 seconds, then let off, then crank it again it'll start and run fine.
but when it starts, the tach will be normal, go up to about 1500 then all of a sudden it loses signal and kicks back down to maybe 500, then goes back up to 1000. just one time, every time. this is maybe the first 2 seconds after startup. all the while the engine is perfectly normal.
there is a little oil in the plugs, 118k miles, and i don't think it's ever has a 60k done, but plugs and wires were changed. car runs fine. its been doin this ever since i got it. codes i've gotten are 452, 177,176, and the fuel pump one. i've changed out the vss since the 452 was making it not shift right, cruise control not working so that fixed it.
i dunno, what do you guys think it is? fuel pump? cam sensor? dis causing hard starting?
