H&R Springs Installed
SHOinVa
Tidewater Va
I've been looking into some performance shocks/struts myself, just haven't decided on what yet.
LMAO Let me know if you find something, I have spent a couple 100 hours trying to find some "performance" shocks for the SHO, unless someone started making them they don't exist. You may find a performance company that makes a general purpose shock that fits but no one makes them for the Taurus and that still leaves you with the struts. Best I can figure the general consensus is the OEM shocks are your best bet. I actually hope I'm wrong and you find something.
Charlie/
stevelaw_2000
Charlie/
How about the stock PP shocks?
SHOinVa
Tidewater Va
Honestly I don't know if there is a difference in the PP shocks, but yea if I remember correctly from the many threads, the best shocks with the least amount of issues where the OEM ones. I think Monroe and maybe KYB do make shocks for the SHO but there not heavy duty or anything, BUT I gave up about a year ago, so it could have changed by now.
C/
Lostneye
NY
C/
The PP and non-PP are different part numbers so there is some differences. $5 says you will not find anything that is direct fit better than OEM.
I agree.
ChinoSHO15
Miami
I need to replace my shocks since i have the HH&R. Springs. I need help since the only thing I find the KYB or Monroe ones????
Wsho
Sacramento California
Today I got a quote to replace two front axles two front hub bearings, Front Strut assembly with H&R springs, sway bar links Front & back and install upgraded Motor / trans torque mounts. Plus a 4-wheel alignment. Have all the parts in my trunk $850 out the door
Wsho
OK I have my springs installed for about a week now and I’m hearing noises every time I turn the wheel. Went back to the shop Friday jacked up sprayed some spray on it so it would stop making noise and nothing. The rubber Mount that’s on top of the strut assembly is loose that the spring mounts to and you can actually move The spring up and down about a 1/4”. Only when the car is jacked up.
Is anyone having this problem
02EC320C 7558 4E36 B5AE CF342F71269A 3762300E 5DEC 47BB A472 D4AAB9B7C290 B166EE81 6EE9 43AF A29B 79AF10C76021
4sfed
I think that's expected. The lowering springs are shorter than stock, so there's some slop when the cars weight isn't on them. The struts are longer than the springs... That's all.
As for the noise, make sure they put the upper mounts back in correctly. There's a mark that looks like a Delta symbol (triangle). They both face (or point) toward the center of the car ( if I remember correctly).
Sent from my Pixel 3 XL using Tapatalk
sperold
Last to Know
Jack it up yourself and measure the height of the spring as accurately as you can. Then check that against the specs from the manufacturer.
It is a long shot, but today's consumer is not above ordering a specified product, opening the box and retrieving the product, and stuffing the box with something similar, and returning for a full refund with the pre-printed label that is included.
This happened to me on front strut assemblies.
