H-Brace Plans?
blue2ndgen
Mi
Does anybody have the dimensions or set of plans for the H-brace. I have a guy with a machine shop that could do it for me I just need some dimensions. Pics would help too. thanks
I've got one that's never been installed and probably never will if you're interested.
60kmaintenance
U.S.A.
Climb under your car and measure!
You can make an H-brace a dozen different ways, as long as it's strong steel or very effectivly deisgned aluminium....
Minnesho
i was wrong
MinneSHOta
I have the plans written out i made measurements one day but they are still at the shop, I'll bring em home and post monday.
twr
whoohoo
half-way there, I think.
I've built a few out of Aluminum and contrary to what some people say Aluminum is plenty strong for this application. Remember, you are only reinforcing the existing H-box, not replacing it.
blue2ndgen
Mi
Would you be able to print me some plans up for that?
blue2ndgen
Mi
I would appreciate it
twr
whoohoo
Edit: Whoops... I over wrote the drawing I had posted, I will fix it tomorrow. Fixed!!
As requested...
I used .125 wall 2" aluminum SQ tube for ends and 1 1/2" Sch.80 pipe of the center struts. I'd say the 2" sq. tube us a must for the ends, the center struts could be made from the same stuff. I used the pipe because it is slightly small and allows welding all round, plus I like how it looks :shrug:
You could use steel too, but remember to paint it or it will rust. I did not drill the holes before hand because I wasn't confident on the measurement. So I stuffed the bracket in and marked them.
twr
whoohoo
SHO Continental said:
nice knuckle braces twr... ;)
Thanks!!
HighSpeed said:
How much does it weigh?
I can'T remember, but I had a steel one in hand that was poorly made and I knew I had the materials at work to do it out of aluminum. I know it weighed 1/3 of the one made from steel.
