Grote Flasher for my 89 SHO?
DeepPower
Searchng4Truth
Texas since 2013
Replaced a burnt out rear brake/directional bulb with a 3157 Sylvania LED bulb. Bulb works but my Lamp Out dashboard light is still lit and my directionals blink fast.
Searching this forum I see that if I install LED bulbs I need a Grote flasher but I'm not sure of the p/n for my Gen 1, I've seen JL-02, EP34, and 44892, all 3-terminal flashers.
The NAPA website shows a GROTE 44810, a 2-terminal flasher but doesn't specifically mention LED. I suspect the Grote 44891 might be correct.
Can someone please tell me what is the correct Grote LED flasher p/n for my Gen 1? Thanks!
Pro*banshee
PA, 16066
How about you just modify the factory one? :)
Figured this out a while back, the potentiometer can be a big or little one from radio shack depending on how pretty you want it to be. cost? <$5.
http://71.112.176.13/casey/Automotive/SHO/LED projects/SHOtails-Grote no-hyper-flash modification.jpg
P.S. - Haven't been here for YEARS at this point, I miss the **** out of my moonlight blue '93 :(
Got some old tech docs for you too, if you just back up the URLS a bit
