Grind noise is back
V
V6&V8SHO
Guest
Started 93 sho up, grinding noise, and up and down revs, put in drive, engine died. started up again and no prob. haven't had grinding for 1 week now. What up?
Rich92forSHO
Collinsville,IL,USA
I had a starter cause a noise like that to me once. Right after the new one went in it failed to disengage completly and made a slight grinding noise that I could hear at cruising speed. I ended up getting another starter. It never caused my engine to stall though. It could also be a water pump, but I would think that it would be constant. I wonder what the possibility of loose corroded metal from the radiator getting into the water pump housing (far out possibility probably).
Rich Boyd and his ol' 92
"Give me that last hp!"
"If I can afford it!"
