Got me a SHO!
droptSHO
Wheaton, IL
I hope this is the right section to post this in. Anyways, I picked this bad boy up last Monday. 94 ATX with 150k on the clock. Runs strong and only 1 owner who was a fanatic about his SHO. The body is almost mint.....no scratches, rust, dings or dents. Iterior is almost mint too, just a cracked driver's seat contol cover. The only mod on it is the catback which I assume is a Dynomax (too damn cold to climb under the car and check :nut: ).
HPIM0531 2
HPIM0534 2
HPIM0535 2
Future big mods:
Cut Intrax with Koni's or Tokico's (if I can find some)
Cowl Hood
Future small mods:
Clear corners
Smoked tails
Speedhut gauges
SHO filler decals (black or silver?)
Remove badges (Looks like they are just glued on, no bolted on, right?)
Tint and maybe wheels too
warmonger
earth
yeah..because the cars so clean i wont give you a hard time about it being the wrong forum...i'd flitz/wetsand/or replace the yellow headlights...the badges arent bolted,but there are holes under them from what i've read?..i'd skip the cut intrax...regular intrax are low enough,too low and it creates other problems...very nice..and enjoy,but remember to take it easy...the ax trans arent bullet proof
JoesSHO
Reality
Too cold to look at the pipe, but warm enough to drive around with your moonroof open? :biggrin: J/K- beautiful ride! Me likes red!
LeddZepp8687
The Keg Rider
Naperville, IL
Ummmmm, by any chance do you park in the parking lot for the apartments right across from COD? If so, there are two other modded SHOs in this parkinglot. Me and syP's.
Ive been looking at the red SHO everytime I pull in, but figured it was a non-enthusiast.
syP
GTP>SHO>*.cars
Wheaton, Illinois
Hey there.....
I PMed you.. check it when you have a chance.
check out... www.shocago.com
that is the chicago SHO club.
Im sure you have seen my Black GTP running around the streets.... if not... my loud ass 95 SHO.
anyways... hit me back.
later
-ryan
droptSHO
Wheaton, IL
No, thats not me. But I do live about 5 minutes from COD. You'll probably see it on the weekends in the Danada Jewel parking lot.
syP
GTP>SHO>*.cars
Wheaton, Illinois
well... how old are ya bud?
in HS??? in college??
what HS did you go to??
all that good stuff... never know... we might know you?
LeddZepp8687
The Keg Rider
Naperville, IL
Oh BTW, The 24 Valve badges can be removed with a heat gun and some fishing line or dental floss, there are no holes, only downside is that the paint is untouched underneath and you will be able to notice the color difference. I had to do some rubbing/buffing to get mine to blend decently, But then again I have 3.2 badges.
http://www.badgeyourride.com/index.htm?page=ordering
They look very nice.
kzoosho
Holset HX52
grand rapids/kalamazoo
I might order my 3.3 badges from them :biggrin:
droptSHO
Wheaton, IL
I removed a badge from my sisters car and had the same color fading problem. But her car is a POS so I don't really care. Are the Taurus and Ford badges glued on the trunk like the side badges?
warmonger
earth
not really..iirc they use a double sided foam "tape"..and the taurus badge leaves three(?) holes in the trunklid,mine just fell off 8-(
LeddZepp8687
The Keg Rider
Naperville, IL
Ford badge and taurus badges have locating holes so you would need to have a body shop fill the holes and repaint the trunklid.
kzoosho: My 3.2 badges look amazing you should order some.
